by absubtle » Fri Mar 19, 2010 6:13 pm
Well, if you dont 'care' about the tune that is on it. You can load a stock rom back on your ECU. But I usually log locked ECU's, to get their ECU ID, then I can start over w/ a stock rom image. I know that is not feasible for most people. Usually w/ Cobb AP version 1, you would still be able to pull the rom and modify it. But AP ver.2 will lock your ECU... so does EcuTek.
Do you have larger injectors, different sized MAF, etc????
There are some options available to you.
Absubtle
CO
