AZ1G700J definition file??
Postby yorl » Mon Mar 15, 2010 12:17 am
Hi everyone! A friend's got a gulf-spec 2009 Subaru STI, whose original file is AZ1G700J. I've been looking for the definition file, but it's been impossible to get something. I've seen there's a similar one on the USDM 2010 STI, would it be safe to use it? (AZ1G701I) Anyways, I'm uploading the stock file. If anyone's kind enough to have a look at it... I'm completely lost!!
Thanks!!
AZ1G700J.hex
Stock gulf-spec MT STI
(1 MiB) Downloaded 828 times
yorl
Re: AZ1G700J definition file??
Postby yorl » Sat Mar 20, 2010 10:00 pm
Nobody?? Pleeeeeeeeeeeease......
yorl
Postby radsdau » Tue Mar 23, 2010 9:01 pm
Have you tried copying the 'I' xml file and renaming it 'J'? You'll have to edit the contents too. It will be pretty obvious once you open the ROM in ECUFlash if the maps line up or not.
Postby yorl » Tue Mar 23, 2010 9:39 pm
Yes, I tried and they do not line up. Not even a single map makes much sense...
yorl
Postby yorl » Sat Mar 27, 2010 7:34 am
Ok, I tried with another definition and it's almost there! I feel like I just need to move a bit the addresses to make it line up. Does anyone know how can I do it???
AZ1G700J.xml
(29 KiB) Downloaded 769 times
yorl
Postby radsdau » Mon Mar 29, 2010 4:49 pm
Hmmm, manually. Takes a while. Not much fun.
