Defining Expressions for Undefined Data. Your thoughts.
I have gotten into disassembly and have been going through the rom figuring some things out. I've found a table that is important to most but am having a hard time figuring out the expression for the unknown Z values.
I know what it i doing, but not real sure on how to impliment a correct expression.
How were the figured?
Example:
8bit value
Max logged in the calculated form (ecu takes this value and calculates it to a standard whole number btw)
is 15d.
So I assume 15/256= expression? since this will be the greatest value possible (according to the ecu) so therefore the expression would have to agree with the largest value.
Is there any other way of determining unknown expressions?
-jerod
Example:
8bit value
is 15d.
-jerod
