Can anyone else open this 06 2.5i rom?
Postby turbosetch » Tue Aug 04, 2009 1:32 pm
All,
I have recently been trying to open a ROM for a 2006 Impreza 2.5i. I have the latest defs and the latest RomRaider software. I tried dumping this code twice and still RomRaider says it can't find the definition for it.
As a test I also found another ROM online and can't open that one as well.
I can open every other rom I have ever tried including one for a 2007 2.5i..Any help here??
sundogbase.hex
(1 MiB) Downloaded 1187 times
turbosetch
Re: Can anyone else open this 06 2.5i rom?
Postby spyder » Tue Aug 04, 2009 9:16 pm
Check out this xml file. Rom ID is E2UE202L.xml
E2UE202L.xml
(492 Bytes) Downloaded 750 times
spyder
Postby turbosetch » Wed Aug 05, 2009 10:44 am
Nope still a no go...I attached the file I am trying to open. Its a stock 2.5i map...This is crazy it makes no sense.
turbosetch
Postby slowb00st » Thu Aug 20, 2009 2:45 am
This one opened it for me, you will need the E2UE102L.xml (should be there from the latest Ecuflash install). Also are you sure its an 06 since from looking at the other .xml E2UE are 07 and for 06 they are E2VH. It looks mostly correct comparing it to other 06 I have tuned.
NOTE: the Intake temp sensor scalling map crashes Ecuflash if you try to open it.
E2UE202L.zip
(365 Bytes) Downloaded 350 times
slowb00st
Postby turbosetch » Fri Aug 21, 2009 4:27 pm
Yeah I don't know are you sure you don't have some other mods with your editor. I have tried adding that file you gave me to the definition lists. Still a no go.
On the other forum I was told there are no defs for this one. So if your able to open it I would love to know how.
turbosetch
Postby slowb00st » Wed Aug 26, 2009 10:33 pm
I only added that definition, and have the latest Ecuflash version.
Maybe it has nothing to do with it but have you tried using a higher user level in Ecuflash?
slowb00st
