Bootloader ECU WRX 2003
Postby zee » Wed May 13, 2009 5:11 pm
Hello, does anybody can me to help the read/write ECu of my Subaru WRX 2003?
I need to know which software and interface is necessary to do the bootloader.
I thank the help
Zee
-Subaru WRX 2003 (12).JPG (90.75 KiB) Viewed 9107 times
-Subaru WRX 2003 (15).JPG (174.02 KiB) Viewed 9109 times
zee
Re: Bootloader ECU WRX 2003
Postby radsdau » Thu May 14, 2009 4:49 pm
That doesn't look like WRX03.
Plastic case, SH7058: looks like either 06/07 DBW serial or 07-09 CAN.
Postby Mad Max » Thu Jun 04, 2009 6:02 am
I have this ECU:
ECU WRX 07.jpg (67.44 KiB) Viewed 8997 times
But it's WRX 07 EUDM.
You have next version of same ECU. So try WRX 07 or STI 07
If you interested I can make detailed photo of main board to compare.
Mad Max
Postby zee » Thu Jun 04, 2009 6:52 am
Hello, mad max, here they are the pictures that I have. I am not sure of the year of the car because here in the py it is difficult to know.
Do you can me to help to read this ecu in boot mode or ZTAG?
Best Regards
Subaru WRX 2003 (14).JPG (696.06 KiB) Viewed 8950 times
Subaru WRX 2003 (13).JPG (680.55 KiB) Viewed 8952 times
zee
Postby radsdau » Thu Jun 04, 2009 3:19 pm
You can't read these in SHBoot mode; the first thing it does when you enter that mode is erase all flash.
Just use ECUFlash.
Postby zee » Thu Jun 04, 2009 4:20 pm
But is it possible to read/writte for the ZTAG?
This ECU is blocked because it was interrupted the flashing
Thank you very much.
Regards
zee
Postby radsdau » Mon Jun 08, 2009 3:13 pm
Don't know about ZTAG (I presume you meant JTAG?). Reflashing is possible using SHBootMode. You need to have a stock ROM file first.
Postby zee » Mon Jun 08, 2009 4:51 pm
I understand, in the outline of the shbootmode I don't know which component is this of the picture.
Do you have a picture of your connected interface in ECU?
I thank your help a lot.
When I get to read this ecu I can ask for the a friend to read ECU of your car to have the ROM.
Regards
zee
Postby radsdau » Tue Jun 09, 2009 2:59 pm
I believe all the SHBootMode pins come out to one of the rows of pads near the back edge of the board. You may have to use a multimeter to trace which pads go to which MCU pins. When I did this (only once), I soldered small wires to these pad holes.
Alternatively I think there are test points labelled as per the schematic above: P409 for instance. That's probably the easier way to go. They're easy to solder to.
Postby zee » Mon Aug 03, 2009 10:08 am
Hello, I put up the interface as show the http://www.openecu.org/index.php?title=SHBootMode but I'm having trouble so that Windows recognizes the hardware.
Where I can find the driver for installation on usb?
Also I do not see the datasheet of the micro the pins that I should connect. Which pins should I connect the interface?
I appreciate the help in advance.
Best Regards
Zee
zee
