subaru forester 1999
Postby sub-bg » Wed Apr 08, 2009 4:35 am
Hi,
I have the rom hex files pulled out from my99 forester.The ecuflsh utility says that it does not recognise the rom using any definition.
I know that the ecu can not be flashed but i want to look at the program structure. would anyone has the definitions for the old European 1997-2001 forester.
Many thanks,
sub-bg
Re: subaru foreser 1999
Postby radsdau » Wed Apr 08, 2009 3:22 pm
How did you get a ROM out of 99 model? AFAIK, ECUFlash only supports 2001- vehicles in the Subaru range.
If you post this ROM, the community may be able to help you further.
Postby sub-bg » Thu Apr 09, 2009 6:00 am
hi, i used a third party software, and this is the rom hex file bellow..
A30117.HEX
engine EJ202/1999
(32 KiB) Downloaded 752 times
Thanks,
sub-bg
Re: subaru forester 1999
Postby sub-bg » Mon Apr 20, 2009 3:34 am
does anyone know how to get lst (list) file from the hex above, so i can see the opcodes and addresses.has anyone got european forester 1997-2000 ?...what is the microcontreller used in the ecu? thanks...
sub-bg
