2006 2.5L STI EU Not reading
PostPosted: Fri Nov 28, 2008 3:13 am
by sms tuner
Hi,
I am trying to read the ROM on a 2006 STI 2.5L but i cant. i opened the Passenger Kick Panel and found the Green Plug already connected and tried to do it with the plug conected and disconnected but every time i get the following message:
[17:38:29.737] Version 1.38.2080
[17:38:29.737] 11 memory models read.
[17:38:29.784] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[17:38:32.857] 264 ROM metadata models scanned.
[17:38:32.857] checksum module "subarudbw" loaded.
[17:38:32.857] flashing tool "wrx02" loaded.
[17:38:32.857] flashing tool "wrx04" loaded.
[17:38:32.857] flashing tool "sti04" loaded.
[17:38:32.857] flashing tool "sti05" loaded.
[17:38:32.857] flashing tool "mitsukernel" loaded.
[17:38:32.857] flashing tool "mitsukernelocp" loaded.
[17:38:32.857] flashing tool "shbootmode" loaded.
[17:38:32.904] flashing tool "shaudmode" loaded.
[17:38:32.904] flashing tool "subarucan" loaded.
[17:38:48.936] Using interface OpenPort 1.3 Universal TX25IvK69687f6c9235423d5075f5e3181d874ea179212ec
[17:38:51.339] kernel get version
[17:38:51.733] SSM2 init
[17:38:51.990] SSM2 ECU ID is 4D 42 59 40 06
[17:38:52.086] Requesting Seed...
[17:38:52.138] Sending Key...
[17:38:52.823] interface close
[17:39:42.625] Using interface OpenPort 1.3 Universal TX25IvK69687f6c9235423d5075f5e3181d874ea179212ec
[17:40:08.467] kernel get version
[17:40:08.857] SSM2 init
[17:40:09.122] SSM2 ECU ID is 4D 42 59 40 06
[17:40:09.216] Requesting Seed...
[17:40:09.263] Sending Key...
[17:40:09.902] interface close
[17:43:26.269] Using interface OpenPort 1.3 Universal TX25IvK69687f6c9235423d5075f5e3181d874ea179212ec
[17:44:17.786] kernel get version
[17:44:18.176] SSM2 init
[17:44:18.441] SSM2 ECU ID is 4D 42 59 40 06
[17:44:18.519] Requesting Seed...
[17:44:18.582] Sending Key...
[17:44:19.221] interface close
Please help.
PostPosted: Sat Nov 29, 2008 4:28 pm
by sms tuner
Anyone please
PostPosted: Sun Nov 30, 2008 3:47 pm
by radsdau
Is the ECU locked?
PostPosted: Fri Dec 05, 2008 5:49 pm
by korhan
i guess you have ppp. ppp uses the same lock with ecutek and map is also made by ecutek.
PostPosted: Wed Dec 10, 2008 1:56 pm
by sms tuner
its a bone stock EU Car. please help
PostPosted: Thu Dec 11, 2008 4:00 pm
by sms tuner
Anyone Please.
Re: 2006 2.5L STI EU Not reading
PostPosted: Sun Dec 14, 2008 11:24 am
by Jon [in CT]
sms tuner wrote:i opened the Passenger Kick Panel and found the Green Plug already connected ...
Then you need to find the second pair of green connectors, maybe below driver's side dashboard.
PostPosted: Tue Dec 16, 2008 2:17 am
by sms tuner
Thank you for your replay. Can someone elaborate on the Connector things. like what is the color of the connector and the location, and if possible a proper procedure that explains what to do exactly.
Regards,
PostPosted: Mon Dec 22, 2008 10:39 am
by AlGontsov
Subaru has 2 green connectors, 1 of them already together, the 2nd one you should find under the plastic cover near the doors (check both passenger and driver), in the passenger feets under the carpet, under the dashboard... then join the 2nd pair, and don't forget to press "read" in the 1st seconds after turning "on" of the ignition, otherwise reading will be failed.
PostPosted: Tue Dec 23, 2008 11:35 pm
by sms tuner
Thank you Sir. That was really helpful.
Chears,
