cant write into ecu!!! 2001wrx Bugeye
PostPosted: Mon Sep 29, 2008 3:07 am
by AVIHAITOPOR
i can read the rom
i cant write to the ecu the new rom. i get this log
[12:29:00.484] Version 1.38.2080
[12:29:00.484] 11 memory models read.
[12:29:00.484] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[12:29:00.703] 264 ROM metadata models scanned.
[12:29:00.703] checksum module "subarudbw" loaded.
[12:29:00.703] flashing tool "wrx02" loaded.
[12:29:00.703] flashing tool "wrx04" loaded.
[12:29:00.703] flashing tool "sti04" loaded.
[12:29:00.718] flashing tool "sti05" loaded.
[12:29:00.718] flashing tool "mitsukernel" loaded.
[12:29:00.718] flashing tool "mitsukernelocp" loaded.
[12:29:00.718] flashing tool "shbootmode" loaded.
[12:29:00.718] flashing tool "shaudmode" loaded.
[12:29:00.718] flashing tool "subarucan" loaded.
[12:29:07.593] A4SE700D (295 tables) inheriting 16BITBASE (424 tables)
[12:29:07.625] 163840 byte image read.
[12:29:10.875] Using interface OpenPort 1.3 Universal TX27zcPvb1eeb4d9bbf8548033dbbb882f0e078e14e14fb6
[12:29:15.890] denso02_bootloader_cmd_start
[12:29:16.109] writing kernel area addr: 020000 len: 0664
[12:29:18.031] kernel get version
[12:29:18.046] kernel version is : OpenECU Subaru HC16 Kernel V1.05
[12:29:18.046] reading kernel comm buffer size
[12:29:18.062] comm buffer size set to 512
[12:29:18.062] reading kernel flash buffer size
[12:29:18.062] flash buffer size set to 4096
[12:29:18.062] Flashing image to ECU memory...
[12:29:18.468] comparing ECU flash memory pages to image file
[12:29:18.468] seg start len ecu CRC32 img CRC32 same?
[12:29:18.468] kernel CRC32 area: addr: 00000000 len: 00004000
[12:29:18.781] FB01 00000000 00004000 3E24E34E 3E24E34E YES
[12:29:18.781] kernel CRC32 area: addr: 00004000 len: 00004000
[12:29:19.109] FB02 00004000 00004000 68792C62 68792C62 YES
[12:29:19.109] kernel CRC32 area: addr: 00008000 len: 00004000
[12:29:19.421] FB03 00008000 00004000 04D1F50C 04D1F50C YES
[12:29:19.421] kernel CRC32 area: addr: 0000C000 len: 00004000
[12:29:19.750] FB04 0000C000 00004000 7C8DCF1E 7C8DCF1E YES
[12:29:19.750] kernel CRC32 area: addr: 00010000 len: 00004000
[12:29:20.062] FB05 00010000 00004000 DF971275 DF971275 YES
[12:29:20.062] kernel CRC32 area: addr: 00014000 len: 00004000
[12:29:20.390] FB06 00014000 00004000 5F1920BF 5F1920BF YES
[12:29:20.390] kernel CRC32 area: addr: 00018000 len: 00004000
[12:29:20.703] FB07 00018000 00004000 B9F21323 B9F21323 YES
[12:29:20.703] kernel CRC32 area: addr: 0001C000 len: 00004000
[12:29:21.031] FB08 0001C000 00004000 3C6EDF0D 3C6EDF0D YES
[12:29:21.031] kernel CRC32 area: addr: 00028000 len: 00004000
[12:29:21.343] FB09 00028000 00004000 17110B5C 8FE64004 NO
[12:29:21.343] kernel CRC32 area: addr: 0002C000 len: 00004000
[12:29:21.671] FB10 0002C000 00004000 671AA763 671AA763 YES
[12:29:21.984] reading ecu programming voltage
[12:29:21.984] programming voltage is 4.32 volts
[12:29:21.984] programming voltage is out of range!
[12:29:21.984] interface close
i need some help
PostPosted: Tue Nov 11, 2008 11:20 am
by jamieWRX2001
have u connected the two green plugs under the steering colum above the pedals and the white plug , or blue depends if u have a 4 pin white plug hangin or a 2 pin white plug hanging .
Re: cant write into ecu!!! 2001wrx Bugeye
PostPosted: Thu Jan 22, 2009 10:25 am
by c0mpl3x
your test connector you need to jumper is green :
