Help me please, no reading ecu
Postby ronisc » Fri Aug 15, 2008 12:58 am
Please can somebody help me.
Its a WRX 2003 Modell.
thats my log
[10:49:54.296] Version 1.35.1650
[10:49:54.296] 11 memory models read.
[10:49:54.296] scanning for metadata models in C:/Programme/OpenECU/EcuFlash/rommetadata
[10:49:54.406] 250 ROM metadata models scanned.
[10:49:54.406] checksum module "subarudbw" loaded.
[10:49:54.406] flashing tool "wrx02" loaded.
[10:49:54.406] flashing tool "wrx04" loaded.
[10:49:54.406] flashing tool "sti04" loaded.
[10:49:54.406] flashing tool "sti05" loaded.
[10:49:54.406] flashing tool "mitsukernel" loaded.
[10:49:54.406] flashing tool "mitsukernelocp" loaded.
[10:49:54.406] flashing tool "shbootmode" loaded.
[10:50:11.703] Using interface OpenPort 1.3b Universal TX282t*92b9574d55baf1c69370eea2528d988824aa83085
[10:50:18.656] SSM2 init
[10:50:19.109] SSM2 init
[10:50:19.312] SSM2 ECU ID is 2E 44 58 41 05
[10:50:21.343] interface close
[10:50:21.359] interface close
[10:50:31.171] Using interface OpenPort 1.3b Universal TX282t*92b9574d55baf1c69370eea2528d988824aa83085
[10:50:32.625] SSM2 init
[10:50:32.812] SSM2 ECU ID is 2E 44 58 41 05
[10:50:34.875] interface close
[10:50:42.687] Using interface OpenPort 1.3b Universal TX282t*92b9574d55baf1c69370eea2528d988824aa83085
[10:50:44.234] SSM2 init
[10:50:44.437] SSM2 ECU ID is 2E 44 58 41 05
[10:50:46.484] interface close
[10:50:46.500] interface close
ronisc
Postby radsdau » Sun Aug 17, 2008 3:10 pm
Check test mode connectors, under the dash (they are green, and should be connected for reflashing).
Also, for that vehicle it appears you might be using the incorrect vehicle type. Make sure you use the WRX01-02 (non-DBW) method.
