2005 LGT ETC ROM ADA3A101A AJ17A
Postby cboles » Tue Feb 28, 2006 11:18 am
another ETC ROM...
2005lgt_stock_ADA3A101A_AJ17A.zip
(10.56 KiB) Downloaded 369 times
Postby Jon [in CT] » Wed Mar 01, 2006 11:22 am
This is the ROM associated with the Electronic Throttle Control processor (not the ECM), right? What is the processor? Glad to see you can access this now.
Postby cboles » Wed Mar 01, 2006 12:13 pm
Correct. It is from the 68HC916 family. I need to do some additional testing, but I think it is similar to the 68HC916R1. The 68HC916Y5 was used in the WRX, which is a bigger chip with more memory. I'll need to investigate more to find out how to reflash it via the K-line. I assume that is possible since you have revealed that there are TSBs for ROM revisions for this part.
Postby 05GarnetLGT » Tue Jun 13, 2006 6:40 am
this is for the 500N/C roms right?
how would I get my 510C ETC rom up here?
05GarnetLGT
Postby Nuked » Tue Jun 13, 2006 8:37 am
05GarnetLGT wrote:this is for the 500N/C roms right?
On that note, I have the 521C on my LGT currently. I would be more than happy to upload if you want (assuming you instruct how).
Jason
Nuked
Postby ev8siv3 » Tue Jun 13, 2006 8:48 am
Jason
I'm pretty sure the 521C has already been posted on here. But the AD3A104J ETC rom hasn't been posted I believe.
I'm curious if the AD3A104K from the 2005 STi will work?
ev8siv3
Postby cboles » Tue Jun 13, 2006 11:50 am
I haven't looked trhough the ETC code much - I expect that it should be possible to read and reflash it over the K-line after doing some reverse engineeering. If there was a code fix in the ETC, they must have a way of deploying that in the field.
I read the ETC out using debugging hardware for HC16s called a BDM (background debug monitor) that I had wired in to the PCB.
Postby 05GarnetLGT » Wed Jun 14, 2006 1:55 am
thats way beyond me, Im only a sophmore EE.
however, its definitely possible to flash ETC roms, over at legacygt.com TDC has custom mapped ETC roms to go with their e-tunes, so that means that the AP already has this functionality.
05GarnetLGT
