STi Immobilizer
STi Immobilizer
Postby greenlimecat » Thu Mar 27, 2008 2:07 pm
2004-2005 STi, is there an immobilizer? I know in the EVO's it is clearly defined in the ROM, but I do not see it in any of the STi files that I have? The reason is that I need to switch out ECU's in a car and I am not 100% sure if that it can be just swapped without anything or that I have to change the immobilizer.
Greenlimecat
greenlimecat
Postby lateapex31 » Fri Mar 28, 2008 8:11 pm
No immobilizer in 04-06 USDM STi ECU.
lateapex31
Postby Jon [in CT] » Sat Mar 29, 2008 7:41 am
lateapex31 wrote:No immobilizer in 04-06 USDM STi ECU.
When you don't know the answer you should keep quiet.
You cannot swap 2004 and 2005 STI ECUs.
Postby lateapex31 » Sat Mar 29, 2008 7:09 pm
Thanks for the clarification. Is the immobilizer code in the ROM? What is the interaction between the ECU and the immobilizer system? I'm almost sure I've swapped ECUs in a 2004 STi without issue.
Otherwise, there are less douche-like ways of correcting people.
lateapex31
Postby Conecrusher » Mon Mar 31, 2008 11:19 am
Boy, this is a good question and lateapex31 asked some good follow up questions, hopefully his last sentance will not get in the way of answering them.
Mike
Conecrusher
Good info, but need the next step
Postby greenlimecat » Tue Apr 01, 2008 6:39 am
Thanks for the info, the chart helps. So onto the more important part--- if it has an immobilizer, where do we find it in the code to change one ecu into another. I know for the EVO's it is already out in the open, but not for the Scooby's. Again, thanks for the input so far.
Greenlimecat
greenlimecat
Postby ciper » Wed Aug 27, 2008 12:26 pm
Any dealer with the current Select Monitor has the ability to pair ECU with immobilizers and/or keys. AFAIC it is not possible for the end user to change this with the current tools. There were rumors that someone knew someone who knew someone who did it with an "insert name of random tool" but they are just rumors.
The simple answer is either -
Buy an 04 STI ecu and change 5 wires so you don't have the immobilizer
Buy an 05/06 STI ecu with matching immobilizer box and at least on key.
ciper
