sorry i think it is a noob question but i am having difficulty reading the rom from our 2005/6 2L AUS liberty GT auto. The only green connector that i could find which is in the right side of the driver foot panel is already connected. then i tired downloading via ecuflash 1.3 and 1.33 and both times the following error happens on ecuflash
[17:32:10.109] Version 1.33.1426
[17:32:10.125] 11 memory models read.
[17:32:10.125] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[17:32:10.406] 219 ROM metadata models scanned.
[17:32:10.406] checksum module "subarudbw" loaded.
[17:32:10.406] flashing tool "wrx02" loaded.
[17:32:10.406] flashing tool "wrx04" loaded.
[17:32:10.406] flashing tool "sti04" loaded.
[17:32:10.406] flashing tool "sti05" loaded.
[17:32:10.406] flashing tool "mitsukernel" loaded.
[17:32:10.406] flashing tool "mitsukernelocp" loaded.
[17:32:10.406] flashing tool "shbootmode" loaded.
[17:32:35.000] Using interface OpenPort 1.3 Universal TX26kFIXe40437d539f0b74e0481beb5e61c0abf91fb0f09
[17:32:38.500] SSM2 init
[17:32:38.687] SSM2 ECU ID is 3C 54 50 41 06
[17:32:38.828] Requesting Seed...
[17:32:38.890] Sending Key...
[17:32:39.671] interface close
[17:32:39.687] interface close
and then if i try again the followin happens:
[17:32:56.734] Using interface OpenPort 1.3 Universal TX26kFIXe40437d539f0b74e0481beb5e61c0abf91fb0f09
[17:32:58.468] SSM2 init
[17:32:58.937] SSM2 init
[17:32:59.406] SSM2 init
[17:32:59.859] SSM2 init
[17:33:00.343] SSM2 init
[17:33:00.796] SSM2 init
[17:33:01.265] SSM2 init
[17:33:01.734] SSM2 init
[17:33:02.203] SSM2 init
[17:33:02.671] SSM2 init
[17:33:03.296] kernel get version
[17:33:03.984] interface close
furthermore the Instrument panel where the odometer is says "ER HC"
It is a tatrix universal cable, because it has the white Mitsu connector and the two subaru plugs. hope someone can help me.
thankx
