critique my noob log plz. :)
PostPosted: Sun Feb 03, 2008 1:31 pm
by kuldud
06 sti w/ mods - map was orignally from the same set up except the turbo was a blouch dominator II
mods below:
sz55 (internally gated)
pe 850cc injectors
perrin fuel rail
aps 70mm cai
perrin turbo inlet
perrin intake elbow
aps fmic piping w/ ssac ic core
walbro 255lph fpump
one step colder plugs
idle log and 4th gear pull. thanks in advance open source guru's!
PostPosted: Wed Feb 06, 2008 10:25 am
by kuldud
anyone? please?
answer
PostPosted: Thu Feb 07, 2008 2:00 pm
by Bamofo
You need to log the correct information and do a good pull. Good pull in an STI is 4th gear from 2000rpms till you get scared or hit redline. Ill attach a file with the correct logging information. Secondly it can look fine on paper but without your rom we cant tell if your hitting the correct boost, if your fuel settings are right etc etc. Log the info correctly and post your rom or pm it to me and ill take a look.
Re: answer
PostPosted: Thu Feb 07, 2008 6:06 pm
by kuldud
Bamofo wrote:You need to log the correct information and do a good pull. Good pull in an STI is 4th gear from 2000rpms till you get scared or hit redline. Ill attach a file with the correct logging information. Secondly it can look fine on paper but without your rom we cant tell if your hitting the correct boost, if your fuel settings are right etc etc. Log the info correctly and post your rom or pm it to me and ill take a look.
the freeway was busy when i did those logs hence the short unfinished run. i'll do some more this weekend.
what about the idle log?
thanks!
rom with a decent log as requested
PostPosted: Sat Feb 16, 2008 3:43 pm
by kuldud
thanks again!
pls see attachments.
PostPosted: Wed Mar 19, 2008 10:39 pm
by kuldud
anything out of the ordinary from my logs?
PostPosted: Mon Apr 07, 2008 9:06 pm
by kuldud
any input guys?
PostPosted: Sun Apr 13, 2008 1:32 pm
by Fbartolo
Nice Tuning with hight boost, What is the model of your turbo?
PostPosted: Sun Apr 13, 2008 4:08 pm
by kuldud
Fbartolo wrote:Nice Tuning with hight boost, What is the model of your turbo?
deadbolt td06 sz55 superzilla. thanks.
