critique my noob log plz. :)
Postby kuldud » Sun Feb 03, 2008 1:31 pm
06 sti w/ mods - map was orignally from the same set up except the turbo was a blouch dominator II
mods below:
sz55 (internally gated)
pe 850cc injectors
perrin fuel rail
aps 70mm cai
perrin turbo inlet
perrin intake elbow
aps fmic piping w/ ssac ic core
walbro 255lph fpump
one step colder plugs
idle log and 4th gear pull. thanks in advance open source guru's!
enginuitylog_20080202_175134.csv
(3.41 KiB) Downloaded 595 times
enginuitylog_20080126_152928.csv
(12.85 KiB) Downloaded 602 times
kuldud
Postby kuldud » Wed Feb 06, 2008 10:25 am
anyone? please?
kuldud
answer
Postby Bamofo » Thu Feb 07, 2008 2:00 pm
You need to log the correct information and do a good pull. Good pull in an STI is 4th gear from 2000rpms till you get scared or hit redline. Ill attach a file with the correct logging information. Secondly it can look fine on paper but without your rom we cant tell if your hitting the correct boost, if your fuel settings are right etc etc. Log the info correctly and post your rom or pm it to me and ill take a look.
Sample.csv
(2.76 KiB) Downloaded 571 times
Bamofo
Re: answer
Postby kuldud » Thu Feb 07, 2008 6:06 pm
Bamofo wrote:You need to log the correct information and do a good pull. Good pull in an STI is 4th gear from 2000rpms till you get scared or hit redline. Ill attach a file with the correct logging information. Secondly it can look fine on paper but without your rom we cant tell if your hitting the correct boost, if your fuel settings are right etc etc. Log the info correctly and post your rom or pm it to me and ill take a look.
the freeway was busy when i did those logs hence the short unfinished run. i'll do some more this weekend.
what about the idle log?
thanks!
kuldud
rom with a decent log as requested
Postby kuldud » Sat Feb 16, 2008 3:43 pm
thanks again!
pls see attachments.
3rdgear pull.csv
(4.09 KiB) Downloaded 586 times
kuldud
Postby kuldud » Wed Mar 19, 2008 10:39 pm
anything out of the ordinary from my logs?
kuldud
Postby kuldud » Mon Apr 07, 2008 9:06 pm
any input guys?
kuldud
Postby Fbartolo » Sun Apr 13, 2008 1:32 pm
Nice Tuning with hight boost, What is the model of your turbo?
Fbartolo
Postby kuldud » Sun Apr 13, 2008 4:08 pm
Fbartolo wrote:Nice Tuning with hight boost, What is the model of your turbo?
deadbolt td06 sz55 superzilla. thanks.
kuldud
