STI 2006 EU 2.5 not reading - HELP
Sat Dec 22, 2007 7:29 am
by mrcsport
I can not get a readout from this model.
Does anyone have a solution?
HEre is a screenshot:
Sun Dec 23, 2007 5:47 pm
by mitsubo
Are the green connectors connected, is car in test mode?
Mon Dec 24, 2007 7:30 am
by mrcsport
yes, green connectors is connected
Tue Dec 25, 2007 4:03 am
by mitsubo
Is your car with electronic throttle? (Drive by wires)
Thu Dec 27, 2007 4:27 am
by mrcsport
car is with electronic throttle
Thu Dec 27, 2007 4:34 am
by mitsubo
You should look for another green connectors which are situated under a plastic cover by the pasanger's right foot
Thu Dec 27, 2007 9:26 am
by mrcsport
there are only 2 white connectors under the passangers feet that I found.
Thu Dec 27, 2007 11:48 am
by mitsubo
Hmmm...when you first found green connectors, were they connected or not, when you connect green connectors do the fans blow when you turn on the ignition?
Was your car flashed with ECUTec before?
Fri Dec 28, 2007 2:52 am
by mrcsport
It is my cousins car, he is not the first owner, so we do not know if it was ECUtec flashed. How can I tell? Is there a way to know? I have read here that they mess it up or lock it somehow. Is there a way to read it if it is ECUtek flashed? Anyhow, yes, I get the fans blowing, and when I found the connectors, they were not connected. Thanks for the answer dude, your'e wery helpful
Fri Dec 28, 2007 5:53 am
by mitsubo
You did everything correct. I think your car was flashed with ecutek, because i succesfully flashed 2 or 3 EDM STi and didn't have any problems.
There is no way to unlock the ecu (yet), now the only solution is to buy a used ecu and to flash it
Fri Dec 28, 2007 6:05 am
by mrcsport
Thank you anyway for your help.
Sat Feb 02, 2008 12:17 am
by letsteyr
your ID is one of WRX but not STI !!!
4342584006 = A8DH200Y which is a WRX !!
Only the green connector has to be plugged. Should work very well
