Enginuity map to Ecuflash?
Postby visualsinz » Thu Nov 29, 2007 9:02 pm
how do i load a map from enginuity to ecuflash so i can flash it to my car?
visualsinz
Postby Dougnutz » Thu Nov 29, 2007 11:42 pm
Dougnutz
Postby visualsinz » Fri Nov 30, 2007 6:06 am
that is a good walk through, but it doesnt answer my questions. i cant pull inguinuity files up in ecuflash to flash them to my car. when i go to open rom and browse, my files that i have for enginuity arent found. help!?!?!
visualsinz
Postby Freon » Fri Nov 30, 2007 11:21 am
What is the file extension? .HEX? .ROM? .XYZ?
It could be Enguinity can see files with different extensions by default.
Just a general Windows tip, you can type in *.* into the open box and it will displace all files. Or you can change the file types you are trying to look for. Many programs have an extra option in the drop down to look at all files rather than just standar file extensions.
Postby visualsinz » Fri Nov 30, 2007 12:01 pm
thank you
visualsinz
