Anyone care to look at my logs and give some input?
Postby slowblackwagon » Thu Nov 15, 2007 7:36 pm
First of all I slightly messed up the logs AND the laptop was attacked by my extremely viscious pitbull while I slept last night(Fat ass jumped out of the bed onto it and cracked the screen :cry: ) But this is what I got. Knock correction slightly escapes me, I think I understand the values but since Im still new to this stuff I doubt myself very quickly.
ecuExplorer [AF426] 11-11-2007 16h46m04s.csv
third gear
(5.92 KiB) Downloaded 575 times
ecuExplorer [AF426] 11-11-2007 16h44m33s.csv
second gear
(3.4 KiB) Downloaded 553 times
slowblackwagon
Postby slowblackwagon » Mon Dec 03, 2007 9:38 pm
Also forgot to add. Stage two free base map, Megan headers and catless up. Shortram intake, Bell mouth catless hooked to the stock catback.
slowblackwagon
Postby thorne » Thu Jan 10, 2008 7:06 am
without seeing your map its hard to tell since you did not log Knock Fine and feedback.
BUT If I rember right this tune ever drops down to 3KC if hts the osec one.I also notice a tiny bit of waver @3757. That makes me wonder if your timing is going wacky there.
You also need to log IAM.
Another thing that needs done is correcting you maf. Your AFR Learning is abit higher then I would like to see.
So please relog and post your map and I will glady go threw it. I might even have a bit safer tune for you Please also do a pull out to higher RPM's because things might be getting worse.
thorne
