AusDM 2.0 LGT boost target B
Postby BoxerFan » Tue May 08, 2007 7:21 am
Hi, am noobie at modding the maps. Need help to understand the boost target B map for AusDM 2.0 LGT 2004, at WOT, the boost target is programmed to drop drastically from 14.5psi@4000rpm to 13psi@4800rpm-6000rpm. That is a 1.5psi drop in that range. Any idea why?
Is it ok to move the boost target at 4800-6000 range higher than 13psi? Any possible risks?
I notice the STI04 boost map is very different from LGT04 2.0L map. Maybe it is because of the smallish VF38 turbo.
BTW, anyone has the compressor map for VF38?
BoxerFan
Postby BoxerFan » Mon Jun 04, 2007 7:12 am
upz.
anyone can point me to the VF38 turbo flow map?
BoxerFan
