2002 Stock Injector Scaling and Latency: EcuFlash
Postby GSknight » Thu Dec 28, 2006 8:11 am
Hello.
I'm just wondering if you guys with WRX's could help me out.
I'm looking for the scaling and latency values for the stock 2002 WRX 440cc injectors.
Could someone post up the stock battery latency values they pulled from their stock ECU?
(I found in a search that some are injectors are scaled to 380 and some to 420: any input?)
Any help you can give me will be greatly appreciated!
Thanks!
GSknight
Postby Jon [in CT] » Thu Dec 28, 2006 3:11 pm
Why not look at a stock 2002 ROM and decide for yourself?
http://www.scoobypedia.co.uk/index.php/ ... yList#toc2
Postby GSknight » Fri Dec 29, 2006 11:22 am
Thanks, That is actally what I did. :D
I scaled the injectors to 380, and used the stock latency values.
Since reflashing it last night, my fuel trims have calmed down drastically.
(I'm using stock 440cc WRX injectors on my Eclipse Turbo project)
GSknight
as I attempt to clear up my afr...
Postby blurexwagon » Tue Jul 24, 2007 2:33 am
:shock: I SO needed to see this, took me about an hour to find, but I'm getting closer to understanding my turbo/injector/pump install & why my fuel is so odd...
blurexwagon
