Where is the green test connector?
Postby tvswitch » Mon Dec 04, 2006 9:12 am
I can't seem to find the green test connector on my USDM 06 STI? Please Help!!
tvswitch
Postby Freon » Mon Dec 04, 2006 4:24 pm
It is under the dash, near the steering column. The two green connectors, you just snap them together It is there somewhere. They shouldn't be hidden.
Postby tvswitch » Mon Dec 04, 2006 8:01 pm
I don't think those green plugs near the steering column are the test connectors for the DBW 06 STI. Because I they came stock preplugged. When i unplug them and plug it back, I don't hear any fan cycling or noise.
Still need help!!! thanks
tvswitch
Postby gregsachs » Tue Dec 05, 2006 9:54 am
there is probably another set on the passenger side that is unplugged then-the standard is to have the driver set unplugged, pass set plugged, but some cars are flipped. check that, the panel to the right of the glovebox should come off relatively easily and i think that is where it is hidden.
gregsachs
Postby tvswitch » Thu Dec 07, 2006 1:04 pm
Thank you..found it..Everything work as expected.
tvswitch
Postby landikar » Wed May 23, 2007 3:02 pm
:mrgreen: You are a good boy gregsachs.Thanks
landikar
Postby MARC CANTWELL » Tue Jul 03, 2007 8:54 am
hey guys i having the same problem i can log my car with enginuity but when i try to read my rom with ecuflash it comes up rear error review log for details or something like that. i do not have any connector hook up so whats the deal here, i know i'm doing something wrong? thanks in advance guys!!!
MARC CANTWELL
Postby Freon » Tue Jul 03, 2007 9:03 am
You have to connect the green test mode connector just as discussed above.
