Dyno Run for a stock MY2006 JDM SpecB 6MT LGT ("D"
Just did my maidan dyno
ambient air temp 32 degrees, humidity 43%
dyno was run in the 4th gear (of 6), fuel octane 98;
There are 3 modes in the car; SI-Drive. The dyno chart shows 2 runs i made, the
lower power / torque lines show the car while
in "Intelligent Mode"
The higher power / torque figures are made while the car is in "Sport Mode"
Between the "Sport #" and "Sport" Modes - there are no real differences
Wheel HP figures are a little disappointing i must say (ie rated crank bhp is
280@6400 rpm, rated torque is 343NM@2400 rpm)
Wheel hp is 103.9bhp@5949rpm / 148NM@3333 rpm for intelligent mode
wheel hp is 165.9bhp@5823rpm / 250NM@3498 rpm for sport mode
crank hp is 180.2bhp@6672rpm / 215NM@3333 rpm for "Intelligent" mode
crank hp is 243.9bhp@6741rpm / 337NM@3498 rpm for "Sport" mode
I have also done some data logging via ecuexplorer ; latency is 170ms
This are logged for the run in "Intelligent" mode
Boost
Ignition Timing
Air Fuel Ratio
Knock
Peak RPM
latency is 170ms
This are logged for the run in "Sport" mode
Boost
Ignition Timing
Air Fuel Ratio
Peak RPM
am still asking for help to be able to download my rom so that i can start playing with it
http://forums.openecu.org/viewtopic.php?t=1116
Boost
Ignition Timing
Air Fuel Ratio
Knock
Peak RPM
latency is 170ms
Boost
Ignition Timing
Air Fuel Ratio
Peak RPM
