IAM in ecuExplorer?
IAM in ecuExplorer?
Postby tshrey » Thu Nov 02, 2006 12:41 pm
I've begun playing with ecuExplorer. I have it working and have made logs, but am unable to find the IAM for my 02 USDM wagon. According to the help file the 0xFF range is for USDM vehicles, but none of those give anything other than -1R when I check them with the car running. If I use the '020124' data I get 16, but that's supposed to be for overseas cars.
Am I doing something dumb?
thanks
tshrey
Postby merchgod » Thu Nov 02, 2006 2:05 pm
0x20124 is the correct offset for IAM for your car. The range will be 0-16. Engine load will be 0x219bd
merchgod
Postby tshrey » Thu Nov 02, 2006 7:34 pm
thanks a lot
So Colby's instructions are just goofed?
tshrey
Postby merchgod » Thu Nov 02, 2006 7:38 pm
I haven't look at the help file of Ecuexplorer, but that is Calvin's program, not Colbys. I assure you that these are the correct addresses.
merchgod
Postby Freon » Fri Nov 03, 2006 1:18 am
IAM is not part of SSM, so it is harder to find. It potentially has to be found for every revision of every ECU.
