Programming Voltage Too Low
Postby PrecisionPB » Tue Oct 31, 2006 9:54 pm
Problem resolved. Issue was software incompatibility. Ecuexplorer would not flash, using Ecuflash immediately rectified the problem. Apparently Ecuexplorer is getting on the old side of things and is a bit glitchy with new hardware. Ecuexplorer still great logging software and great for realtime date with conversions, but I'd use something else to flash.
Car:
2004 WRX
Using Ecuexplorer
Tactrix 1.3 cable
Upon connecting the cable, I am able to view the ECU (version, realtime info) and run a test flash with no problems. However, when I actually attempt to flash, the process fails before the flash is attempted with the following error: "Programming voltage too low."
Voltages range from ~4.1 - ~4.5 with jumper connected. I have tried to flash with no jumpers, with the greenies (when I say greenies, I mean the ones under the steering column) connected w/ jumper block, jumper block with no greenies... no change in error message. What very little information I can find on this error message points to a defective cable, but no indication of that exists.
Please help :)
Thanks.
PrecisionPB
Postby xswrex » Tue Oct 31, 2006 11:05 pm
You need to have the both the green connectors and the jumper plug connected.
Check the white jumper plug for proper connection. The voltage range you are mentioning is for sure a sign of a poor connection.
xswrex
Postby m3n0ch3 » Wed Nov 01, 2006 9:27 am
was the car cold?
It happened once to me after a freezing night....
started the car for 5-6 minutes to warm it up and it went fine ;)
m3n0ch3
Postby PrecisionPB » Fri Nov 03, 2006 8:38 am
Car was warm.
Checked the jumper with a meter, jumper is good. Gonna try Ecuflash instead of Ecuexplorer and see if I have any better luck. Perhaps Ecuexplorer isn't feeling my 1.2 cable?
PrecisionPB
Postby PrecisionPB » Wed Nov 08, 2006 6:04 pm
Solved.
PrecisionPB
Postby pulski » Thu Nov 09, 2006 6:55 am
Solution?
pulski
Postby PrecisionPB » Sat Nov 11, 2006 8:53 am
Has been posted in the first post.
PrecisionPB
