2005 2.5 RS rom
2005 2.5 RS rom
Postby tekgnosis » Sun Oct 29, 2006 5:46 pm
Attached is the rom I pulled from a 2.5RS. Any help with a definition would be cool. I'll post it up on enginuity.org as well.
rs25_base.bin
(1 MiB) Downloaded 1203 times
tekgnosis
Postby prana » Tue Jan 02, 2007 10:13 pm
I am sorry I couldnt assist with creating the XML but if I may ask, was there any tricks to pulling the image out of the ROM ? Mine just plain refuses to read, it was a 2002 2.5 RS though
prana
Postby maxiav » Mon Aug 20, 2007 10:59 am
any news on this???? Has anybody made any progress on this ECU?
maxiav
Postby ravenhil » Tue Oct 02, 2007 6:45 pm
wow how did you do it??? pulling the rom off??
ravenhil
Postby impreza.srx » Tue Apr 29, 2008 4:16 am
I know this is an old post..
But how oh how did you pull the ROM off the ECU?
I have just removed, and re installed ECUFLASH with the new defs, but no luck... All I get is the following:
[22:05:07.390] Version 1.34.1435
[22:05:07.406] 11 memory models read.
[22:05:07.406] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[22:05:07.546] 233 ROM metadata models scanned.
[22:05:07.546] checksum module "subarudbw" loaded.
[22:05:07.546] flashing tool "wrx02" loaded.
[22:05:07.546] flashing tool "wrx04" loaded.
[22:05:07.546] flashing tool "sti04" loaded.
[22:05:07.546] flashing tool "sti05" loaded.
[22:05:07.546] flashing tool "mitsukernel" loaded.
[22:05:07.546] flashing tool "mitsukernelocp" loaded.
[22:05:07.546] flashing tool "shbootmode" loaded.
[22:07:21.765] Using interface OpenPort 1.3 Universal TX27Bvtw76c3f4d53675fa04f1d6f46f1966815fa5e3edb3
[22:07:23.843] SSM2 init
[22:07:23.984] SSM2 ECU ID is 3D 52 10 30 05
[22:07:23.984] SSM2 read ram byte addr: 000061
[22:07:24.046] ECU is in test mode
[22:07:24.124] SSM2 init
[22:07:24.281] SSM2 ECU ID is 3D 52 10 30 05
[22:07:26.312] interface close
[22:07:26.328] interface close
[22:07:34.062] Using interface OpenPort 1.3 Universal TX27Bvtw76c3f4d53675fa04f1d6f46f1966815fa5e3edb3
[22:07:35.812] SSM2 init
[22:07:35.953] SSM2 ECU ID is 3D 52 10 30 05
[22:07:37.999] interface close
[22:07:38.015] interface close
[22:07:44.171] Using interface OpenPort 1.3 Universal TX27Bvtw76c3f4d53675fa04f1d6f46f1966815fa5e3edb3
[22:07:45.437] SSM2 init
[22:07:45.578] SSM2 ECU ID is 3D 52 10 30 05
[22:07:47.624] interface close
[22:07:53.531] Using interface OpenPort 1.3 Universal TX27Bvtw76c3f4d53675fa04f1d6f46f1966815fa5e3edb3
[22:07:55.749] denso02_bootloader_cmd_start
[22:07:56.968] denso02_bootloader_cmd_start
[22:07:58.187] denso02_bootloader_cmd_start
[22:07:59.406] denso02_bootloader_cmd_start
[22:08:00.624] denso02_bootloader_cmd_start
[22:08:01.046] kernel get version
[22:08:01.390] interface close
[22:08:07.406] Using interface OpenPort 1.3 Universal TX27Bvtw76c3f4d53675fa04f1d6f46f1966815fa5e3edb3
[22:08:08.843] SSM2 init
[22:08:08.984] SSM2 ECU ID is 3D 52 10 30 05
[22:08:11.031] interface close
[22:08:11.046] interface close
[22:08:17.343] Using interface OpenPort 1.3 Universal TX27Bvtw76c3f4d53675fa04f1d6f46f1966815fa5e3edb3
[22:08:19.578] denso02_bootloader_cmd_start
[22:08:20.796] denso02_bootloader_cmd_start
[22:08:22.015] denso02_bootloader_cmd_start
[22:08:23.234] denso02_bootloader_cmd_start
[22:08:24.453] denso02_bootloader_cmd_start
[22:08:24.874] kernel get version
[22:08:25.218] interface close
[22:08:25.234] interface close
[22:08:52.812] Using interface OpenPort 1.3 Universal TX27Bvtw76c3f4d53675fa04f1d6f46f1966815fa5e3edb3
[22:08:54.359] SSM2 init
[22:08:54.499] SSM2 ECU ID is 3D 52 10 30 05
[22:08:56.546] interface close
[22:08:56.562] interface close
impreza.srx
