I tried to adjust my friends rev limiter on his 06 wrx. Pulling the rom from the ECU was no problem. It asked me to define the rom from scratch or chose from a parent ROM, which I did. But when I went to change the parameters nothing came up... any ideas?
it only shows me two parimeters under timing there is a main ignition A and main ignition B and then a Misc Checksum table. The values for the ignition table are all screwed up though and they don't make any sense. Also shouldn't there be more parimeters then just those two??
Yeah, there's a lot more than that. You either inherited it wrong or you are launching an old version of Ecuflash (maybe from an outdated shortcut)? Try uninstalling ecuflash and reinstalling it. Then make sure you inherit the A8DH200X rom for your rom.
Go to the rommetadata directory in Ecuflash and then to Subaru and then to wrx. Look for the A8DH201X.xml file and delete. Then open it in Ecuflash and inherit the A8DH200X.
