Quirks with an AH580?
I just got my swap running today and drove it
It is a 2003 JDM EJ207.
After driving it for a while, A/F Correction is always pegged at +25% at idle. Is this normal?
I keep thinking a bad ECM, but I hope it is not. KC is normal at 0. Injector Pulse is kindal low at 1.97 to 2.05. A/F sensor from Lamda to AFR shows 15:1 to 17:1.
From previous experience, all A/F Learn and Correction numbers should be relatively close to the value of 0%, +/- 10%
Would it be a good idea to update to an AH581, as that is all I usually see on the Twin Scroll ECM being discussed?
Thanks,
-phill
Thanks,
-phill
