wrx v-limited '05
PostPosted: Sat Oct 14, 2006 12:56 am
by swiffly
this one is the most beautiful wrx i've seen in my life stock
but i can't read the map in ecuflash..............so.............HELP
'05 RHD jdm subaru wrx 5speed
we imported this one, so its jdm for sure....
PostPosted: Sat Oct 14, 2006 6:40 am
by merchgod
This was recently added to Enginuity definitions ( www.Enginuity.org ).
Or, if you would like to use Ecuflash, add the attached xml file to your rommetadata/subaru/wrx directory. I wasn't sure of the flashmethod, so I left it blank (it is probably wrx02). So, when you go to flash you'll need to update that.
Make sure you are using version 1.29a.
PostPosted: Sun Oct 15, 2006 1:36 am
by daddyhaw
flash method is indeed wrx02
