Tuning of a US MANUAL WRX 01/02 - AF424 - A4SGD10C
Postby west_minist » Sun Jun 11, 2006 12:57 pm
I am not sure why that info came out so. I did not look down there, but in the dyno info, 99 is there.
I will re-edit.
Would you care to remove the post above to reduce page length
Postby west_minist » Sat Jul 22, 2006 4:00 pm
v3-2 Boost Curve
Please note this boost curve looks so since the car was not driven for logging.
Postby JRSCCivic98 » Sun Jul 23, 2006 8:34 am
west_minist wrote:Please note this boost curve looks so since the car was not driven for logging.
What does that mean? :roll:
Postby west_minist » Sun Jul 23, 2006 8:45 am
It means that instead of a full WOT in any gear to produce this curve, there was mix throttle.
I ask the people that I help to do WOT in 2, 3 and sometimes even in 4th gear from as low an rpm as possible, for me to see how the boost curve looks and the effective load, kc, afr and so on.
Postby JRSCCivic98 » Sun Jul 23, 2006 8:46 am
Pertaining to the AFR, how do you know what it's at?
Postby Jon [in CT] » Sun Jul 23, 2006 1:41 pm
west_minist wrote:It means that instead of a full WOT in any gear to produce this curve, there was mix throttle.
So why bother to post it if it's useless?
Postby west_minist » Sun Jul 23, 2006 1:45 pm
Because I was ask to and it is the best I have, but its shows close to what the actual responses I see.
Crawford Perf. :)
I like this tagged team :)
Can both of you post yours for reference. If you have any others you have come across, please post those too.
Re: Tuning of a US MANUAL WRX 01/02 - AF424 - A4SGD10C
Postby subgenius » Sun Oct 29, 2006 5:34 pm
west_minist wrote:The car has JDM full learning...
What does this mean?
subgenius
Postby west_minist » Sun Oct 29, 2006 7:30 pm
All of the ignition stuff, including others. It is only a few settings.
Eg, Fine Ign. Learning Advance Interval
