Does anyone know anything about the AF530-7554 (A4SE700D)
Postby NeverLies » Fri Aug 18, 2006 1:06 pm
Hi det maps are used when you got quite la lot of knock so I don't understand why it is crazy to get really reach in this condition ???
Postby menfou » Fri Aug 18, 2006 1:24 pm
For 4400rpm with 3.40 in Hi Det Fuel Map I see 10.01
For 4400rpm with 3.36 in Hi Det Fuel Map I see 10.81
For 5600rpm with 3.36 in Hi Det Fuel Map I see 10.12
10.12 it's for 10.12:1 for A/F
Escuse me but I don't know ecuEdit or EcuFlash for moment.
I know only AEM EMS, Hondata and it's never in A/F but only in injectors pulse in millisecond
menfou
Postby menfou » Sat Aug 19, 2006 9:50 am
I tuned mw WRX EU.
Before 240hp
After 277hp
I modify Ignition, Fuel for 11.5:1 on my AEM Wideband, and boost
menfou
Postby venom79 » Mon Aug 28, 2006 11:16 pm
Menfou!! I send you pm..
venom79
Postby menfou » Mon Aug 28, 2006 11:34 pm
You will have my rom in 4 hours ;)
menfou
Postby FrSTi » Tue Aug 29, 2006 2:41 am
menfou wrote:For 4400rpm with 3.40 in Hi Det Fuel Map I see 10.01
If the car is fine on IAM (16), you shouldn't get any change by altering the Hi det fuel map.
The fuel map switching is set at 7, on top of this value, your Ecu reads the low det fuel map (obvious ;)).
Extreme caution is required here...
FrSTi
