Latest work for 2004 USDM STI, GT30 turbo map
Postby STIBungy » Wed Nov 01, 2006 2:28 pm
What's your af correction look like with that maf and injector scaling?
STIBungy
Postby Freon » Wed Nov 01, 2006 6:19 pm
AF correction is fine. It moves around, but generally stays within +/- 10. Keep in mind there is more to it than just the MAF and injector scaling.
Postby STIBungy » Sun Dec 24, 2006 11:03 pm
Do you have the dual port external wastegate hooked up? On mine, I only have the top port hooked up.
STIBungy
Postby Freon » Wed Dec 27, 2006 12:05 pm
I have played with several setups with 3 and 4 port solenoids.
If you only run one port, it should be the BOTTOM port. The one where positive pressure pushes the port open. The top port pushes the wastegate shut harder. If you only use the top port you are probably going to severely overboost.
You can run it just like a normal single port wastegate with the bottom port and leave the top port open. I've seen a few different setups with a single 3 port setup and a dual port wastegate, but this works fine. It might make your boost "shake" a bit more than using the top port as a sort of air brake.
