2007 WRX MT - A8DK100X
Postby shane86 » Wed Nov 15, 2006 1:29 pm
FRESH MEAT! COME 'N GET IT!
My friend Eli just took delivery of his brand new 2007 WRX, and the first thing we did was head back to my place and pull the ROM off to get you guys something to work on! :lol:
07_WRX_MT-A8DK100X.HEX
2007 Subaru WRX 2.5L MT - A8DK100X
(1 MiB) Downloaded 2459 times
shane86
Postby Jeramie » Wed Nov 15, 2006 6:51 pm
What exactly did you have to do to pull the rom?
http://forums.openecu.org/viewtopic.php?p=10103#10103
Jeramie
Postby shane86 » Wed Nov 15, 2006 8:08 pm
Just what i've always done.
1. Connect OpenPort 1.2 to car
2. connect green test connectors
3. connect OpenPort 1.2 to laptop (already on)
4. turn car on
5. launch ECU Flash 1.28.716
6. initiate ROM download
7. select "2005-2006 Subaru DBW models" when prompted.
8. ECU download commenced.
9. when it asked for a profile, i selected to create a new profile based on the 06 WRX and saved the file.
that's it. it just worked. nothing out of the ordanary.
shane86
Postby zigzagzok » Wed Nov 15, 2006 11:05 pm
shane86 wrote:Just what i've always done.
4. turn car on
am using openport 1.3 cable - wonder if there is any issue
zigzagzok
Postby shane86 » Thu Nov 16, 2006 6:00 am
i can't really see why... they're practically the same cable.. i'm pretty sure i have a 1.2, but it might be a 1.3.
i'd look more towards the software frankly. 1.29 has been having little issues everywhere, and i wouldn't be surprised if this is one of them.
shane86
Postby shane86 » Thu Nov 16, 2006 6:03 am
Actually, it looks like the problem is 1.29
1.28 has just worked on a second car, one of the same people who has been having problems reading with 1.29.
so it looks like 1.28 is needed to work with these cars.
what's up with 1.29?
shane86
Postby Jeramie » Thu Nov 16, 2006 6:15 am
Anyone got defs yet? IAM or enginelaod yet?
Jeramie
Postby Shibbs » Sun Nov 26, 2006 6:27 pm
Any news on this yet? I'm already sick of stock!!
Shibbs
Postby Jeramie » Sun Nov 26, 2006 7:07 pm
I've started tuning mine. :D
Jeramie
Postby Shibbs » Mon Nov 27, 2006 3:51 pm
When you get a good baseline, let me or Shane86 know. Thanx!!
Shibbs
Postby Jeramie » Mon Nov 27, 2006 4:14 pm
The 07 is identical to the 06 as far as I can tell so far. osecuroms.org has a stg1 06 posted. It just needs to be copied over to the 07 base rom and that should be a pretty good starting point.
Jeramie
Postby Shibbs » Tue Dec 12, 2006 2:11 pm
Ha, finally registered.
Anyway. ECU stuffs now.
What about the timing issues under 3800 revs? the 11*zashaetyat or whatever. Takes everything times 11, and causes it to predet bad.
Shibbs
Postby Jeramie » Tue Dec 12, 2006 3:46 pm
I've yet to have any problems with the timing or det.
I had a small issue with timing while cruising (Ie light throttle still under vacume) but other than that.... not too many problems..
Do you have logs? With the problems you are describing?
From what I have read timing under 3800 can't be less than 12 degrees? If your runing 93 octan, you really don't want your timing to be less than 12 degrees? Right? So as far as I can tell, this should really only be a problem for people runing 91..
Jeramie
Postby gabedude » Thu Jan 18, 2007 1:41 pm
Can you guys see the Speed limitter (fuel cut based on MPH) cell, or is it grayed out?
I am using ecuflash 1.29a and on all of the 06 maps that I have d/l, it is grayed out and needs the address in the rom file.
Can you guys using 1.28 modify this field? I tried all of the different user experience levels and it is still grayed out.
gabedude
Postby Shibbs » Wed Jan 31, 2007 8:10 pm
Yes, Shane86 could see my top speed using 1.28. 149 mph.
Shibbs
