A2ZJB10J 2005 STi ECU
Postby ECUBlues » Wed Jul 05, 2006 1:31 pm
I am able to dump from the ECU, but at that point I have list of tables that are quite jumbled. Also when I try to edit, for example the Low Det Fuel Maps, it decides to have a mind of its own---- numbers jump and it is not just added as I had instructed it to do so. I can supply the ROM file and any other info as necessary... my end is tuning, as far as programming---- that is another story.
On the positive side, EVO IX--- No problems and works like a charm.
ECUBlues
Postby Freon » Wed Jul 05, 2006 4:27 pm
That is most likely an XML problem.
What program are you using to edit? Just Ecuflash? Or are you using Enginuity or Ecuedit?
Postby ECUBlues » Thu Jul 06, 2006 6:30 am
Freon wrote:That is most likely an XML problem.
I am using ECUFlash and I created the XML file with Stylus Studio from one that you had linked to. Any help woud be greatly appreciated as once I get the hang of it--- I will be better able to contribute
ECUBlues
Postby Freon » Thu Jul 06, 2006 7:42 am
Well you're on your own with Stylus Studio.
You need to create the correct XML to start with. Do you know how to use XMLwrite? If so, it will directly create a valid XML.
The XML I linked? Which XML that I linked where? Unless it is the exact right XML for YOUR exact ECU, it won't work. I.e. an XML for a AJ2Z500J will not work with a AJ2Z700J ecu. I don't think I've ever posted one for your ecu. I've never had a A2ZJB10J rom dump.
Post your ECU rom dump file. This is always step #1 to getting help with editting.
Postby 4EVO2NV » Fri Sep 15, 2006 2:16 am
just us enginuity
4EVO2NV
