2003 USDM Legacy EJ25
Postby 91 XR7 » Fri Dec 07, 2012 7:59 pm
I have a Tractix Openport 2.0 with ECUFlash, and it worked good at removing Fault codes (couple of Evap codes and such) on a 2002 WRX ECU/Engine what i've installed into a Replica 356 Porsche.
Is there anyway to do the same on a 2003 USDM Legacy with a NA 2.5L ? Tuning part i don't care about, i just like to be able to remove the Fault codes for systems that are not fully installed (Evaporative Emissions)
Added:
the ECU has a part number 22611-AJ20A, which i found by searching online is a 2004 Legacy ECU, but 2004 Legacy's were DBW? This setup is not. The harness is correct for a 2003 Legacy for Pin-out and even colors, and plug into the ECU no problem either
Any thoughts or ways to make this happen would be wonderful to know
Thank you
91 XR7
