Hi guys,
I've been searching everywhere for this but I don't seem to be having much luck
I'm wondering if anyone would know where I could get hold of an ignition base map for the EJ201 SOHC Manual? I've had a look at some of the RomRaider ROMS and came across a B4 Liberty but that's DOHC. I also found a development rom called Hitachi 22611_AJ610_512kB.bin which is for an EJ201 but it's saying unsupported ROM. I tried loading up this ROM in ECUFlash and going through the steps there but when I put in the base address of 200 or 2000 with length of 8 it wasn't giving me any usable ECU ID.
The reason I'm after the ignition map is because I have a supercharged subie with the EJ201 and am using an aftermarket ECU - the values I've got are safe but I just need to compare them to the original for the normal side of things not under boost.
Cheers
