Here's some more, maybe my work can help some people with the 2004 ol/cl problems too.
2004 WRX OFFSETS
"3D MAPS"
2A66B-2A67A = MAX WASTEGATE DUTY RPM SETTINGS (VERTICAL)
2A67C-2A68B = MAX WASTEGATE DUTY THROTTLE SETTINGS (HORIZONTAL)
2A68E-2A6CD = MAX WASTEGATE DUTY DATA VALUES
2A701-2A712 = DESIRED BOOST AUTO RPM SETTINGS (VERTICAL)
2A714-2A723 = DESIRED BOOST AUTO THROTTLE SETTINGS (HORIZONTAL)
2A726-2A76D = DESIRED BOOST AUTO DATA VALUES
2A780-2A782 = BOOST AIR TEMP / RPM COMP RPM SETTINGS (VERTICAL)
2A785-2A788 = BOOST AIR TEMP / RPM COMP AIR TEMP SETTINGS (HORIZONTAL)
2A78B-2A78E = BOOST AIR TEMP / RPM COMP DATA VALUES
2AFED-2AFF0 = EGT LIMIT RPM SETTINGS (VERTICAL)
2AFF2-2AFF5 = EGT LIMIT LOAD SETTINGS (HORIZONTAL)
2AFF8-2AFFB = EGT LIMIT DATA VALUES
28DCE-28DED = LOW DET FUEL MAP RPM SETTINGS (VERTICAL)
28DEF-28E0A = LOW DET FUEL MAP LOAD SETTINGS (HORIZONTAL)
28E0D-28EEC = LOW DET FUEL MAP DATA VALUES
28EED-28F10 = HIGH DET FUEL MAP RPM SETTINGS (VERTICAL)
28F12-29F2D = HIGH DET FUEL MAP LOAD SETTINGS (HORIZONTAL)
28F30-2902B = HIGH DET FUEL MAP DATA VALUES
293AA-293C7 = MAIN IGNITION RPM SETTINGS (VERTICAL)
293C9-293E8 = MAIN IGNITION LOAD SETTINGS (HORIZONTAL)
293EB-294DA = MAIN IGNITION MAP DATA VALUES
29880-2989F = IGNITION CORRECTION MAP RPM SETTINGS (VERTICAL)
298A1-298BA = IGNITION CORRECTION MAP LOAD SETTINGS (HORIZONTAL)
298BD-2998C = IGNITION CORRECTION MAP DATA VALUES
"2D MAPS"
2A6D4-2A6D9 = PRIMARY WASTEGATE DUTY ATMOSPERIC PRESSURE COMP
2A6DE-2A6ED = PRIMARY WASTEGATE DUTY AIR INTAKE TEMP COMP
2A7C9-2A7DA = TURBO DYNAMICS PROPORTIONAL BURST
2A7A3-2A7B4 = TURBO DYNAMICS PROPORTIONAL CONTINUOUS
2A774-2A77F = BOOST PRESSURE ATMOSPERIC PRESSURE COMP
291F9-29204 = BOOST LIMIT
286C3-286CC = INJECTOR OPENING TIME COMP
29524-29533 = IGNITION INTAKE TEMP COMP
2808A-280E9 = AIR FLOW SENSOR SCALING
2A967-2A96E = CAT THRESHOLD 2 FAIL ABOVE
2A979-2A980 = CAT THRESHOLD 2 FAIL ABOVE B
2827C-28283 = FRONT O2 SENSOR ATM PRESSURE COMP
282AF-282C8 = FRONT O2 SENSOR SCALING
2AEE1-2AEEA = BOOST SOLENOID CEL MAP THRESHOLD
29107-29118 = THROTTLE DELTA FUEL COMP (DELTA)
2911D-2911E = THROTTLE DELTA FUEL COMP (RPM)
29125-2912D = THROTTLE DELTA FUEL COMP (BOOST ERROR)
29132-29141 = THROTTLE DELTA FUEL COMP (COOLANT TEMP)
"DATA VALUES"
291C8-291CB = REV LIMIT
??? = FUEL MAP KNOCK SWITCH THRESHOLD
299D5-299E2 = KNOCK LEARNING LOAD THRESHOLD
299E5-299F2 = KNOCK LEARNING RPM THRESHOLD
2A7DC-2A7DE = BOOST BASED SPEED LIMITING
??? = INJECTOR FLOW SCALING
??? = MAF SENSOR FLOW LIMIT CEL
291E9-291EC = SPEED LIMITING AUTOON/MANON/AUTOOFF/MANOFF
??? = INITIAL ADVANCE MULTIPLIER
2998E-29995 = COARSE IGNITION LEARNING RPM RANGE
29996-2999D = COARSE IGNITION LEARNING LOAD RANGE
??? = FINE IGNITION LEARNING ADVANCE INTERVAL
??? = FINE IGNITION LEARNING ADVANCE MAGNITUDE (ALPHA)
299FB-29A02 = FINE IGNITION LEARNING RPM RANGE
29A03-29A0A = FINE IGNITION LEARNING LOAD RANGE
299C8-299CF = KNOCK DETECTION RPM RANGE
299D0-299D3 = KNOCK DETECTION MINIMUM LOAD
??? = FUEL MAP RESULT BEFORE RAMPING INSTEAD OF JUMPING
28D6C-28D71 = ENGINE OPERATION PERIOD THRESHOLDS
??? = IGNITION LEARN RETARD MAGNITUDE - GAMMA
28D60H-28D61H = CLOSED LOOP MIN COOLANT TEMP
28D62-28D65 = CLOSED LOOP MAX RPM
28D66-28D67 = MAX CLOSED LOOP VEHICLE SPEED
28D68-28D69 = MAX CLOSED LOOP EGT
28D6A-28D6B = MAX CLOSED LOOP EGT (HI DET)
28D5A (???NOT POSTIVE) = DELAYED OPEN LOOP FUELING THROTTLE THRESHOLD
28D72-28D91 = OPEN LOOP DELAY PERIOD
CL MODIFIED LOAD: 0x28d5d
