Please Help
Please Help
Postby vbherrera » Thu Nov 01, 2007 7:14 am
I flashed a stage 2 map onto my car.. My car feels like it breaks right after getting into boost.. Like at 3500 rpms my car feels like it just stops.. I logged 1,2,3rd gear.. Please tell me if you know what is wrong.. i also got a check engine when i did the flash..
on the stock map i did not have a cel.. but the car would cut out real hard at 4k
mods:
pnp stock turbo
tbe no cats
pnp headers
uppipe
enginuitylog_20071101_105432.csv
(3.42 KiB) Downloaded 488 times
vbherrera
Postby Freon » Thu Nov 01, 2007 12:43 pm
Timing dips really low, and there is a lot of timing being pulled at lower RPM. It doesn't seem very happy.
I dunno, that map looks like it is running like junk on your car overall. What map is this? You might try finding someone to custom tune your car.
Are you actually getting a CEL? Or does it just flash when this happens then go away? If it just flashes but doesn't actually leave a CEL, that's misfire. It can be caused by lots of things, but checking your plugs would be a good start.
It could be the map is running way too lean causing misfires. Usually the front stock O2 sensor will go right down to 0.72 in boost because it was not made to read correctly under boost. Yours is not doing this, which kinda makes me think you're running way lean. You really need a wideband to tune fueling.
