I've got a larger 440HP Turbo with 15psi Actuator and Perrin EBCS 3 Port boost solenoid. I have a problem controlling boost and am hoping someone can point me in the right direction.
My boost map (Target Boost D) shows 15.82psi but when I go WOT it spikes beyond 20psi hitting fuel cut. This only started occuring after the EBCS and Turbo went on. And my guess is its one of the Wastegate maps that I need to ajust to accommodate.
Can some give my insight on what I need to log for in EcuExplorer and which Boost/Wastgate map needs ajusting?
Cheers!
