error while rescaling maf
Hi all.
I installed a perring big maf tube and wanted to rescale the Maf using the Air Flow Sensor Scaling Table.
I used XMLWRITE to create the XML file for my ecu, this works ok.
When I open the Table using Ecuedit (latest version) and insert the new values the values are stored in the table and the graph rises ok.
However when I save the ECU-File and reopen it all values in the table higher than 300 are not stored correctely, only the last two digits are stored, so I entered 307.95 and after save there is 7.95 in the table...
Does anyone know the problem since this messes up my mapping!
I will attach a picture of the graph after saving, the problem starts as soon as value 300 or higher needs to be inserted.
I hope someone has an idea!
PS my ECU type is A4RN1XXX
