Hey All-
Getting into some analysis between my current ECU and an ECUTek'd ECU I bought 2nd hand. Some initial observations and questions. I'm using Enginuity as my map interface...
1) ECUTek'd ECU is based on A4SGC00C, the A4SGE01C has a ton more defined parameters. Things like tip-in fueling, turbo dynamics, wastegate duty compensation and MAF scaling are not there for A4SGC00C.
- Why are the ROM's not reporting the same amount of parameters?
- Is it just an Enginuity def's issue?
- Do they have a different location in ROM?
2) Under the fuel tables, the ECUTek'd ECU max load values go much higher than in the stock map (6.5g vs 4.12g)
- I thought this was a limitation of the stock MAF, am I missing something?
Anyone know what the "TGV Control Signal Open cct DTC threshold" value does. Default value is "10", but want to know what it is measuring (10 of what)?
Sorry if these are noob questions, b/c I'm a noob.
-Jason
