2008 JDM WRX STI 2.0 litre
Postby ptharris » Fri Mar 06, 2009 7:37 pm
ptharris
Re: 2008 JDM WRX STI 2.0 litre
Postby radsdau » Sun Mar 08, 2009 3:34 pm
ptharris wrote:...do i need to place the car into test mode?..... also on the older sti which plug do i need to bridge to flash rom, i didnt get the connecters with the open port 2 cable
As far as I have seen to date, none of the CAN vehicles require any extra connectors to be plugged in, just the OpenPort2 cable.
01-05 style ECUs (non-DBW) require both the test mode connector to be joined (sometimes 2 sets), and also a jumper block to be connected.
04-07 style ECUs (DBW, non-CAN) require only the green test mode connectors.
Postby ptharris » Mon Mar 09, 2009 8:24 pm
thanks, i am about to pull rom image, i will post it in the rom section for users to look at (this is a bone stock JDM 2.0litre)
ptharris
Postby ptharris » Mon Mar 09, 2009 9:37 pm
2008GRBSTI_JDM_std.hex
(1 MiB) Downloaded 1781 times
ptharris
Postby gordon1 » Mon Jan 25, 2010 3:00 pm
hi how did you get on with this
thank you
gordon1
Postby ptharris » Wed Jan 27, 2010 12:39 am
yeah all good, stage 3 now. LOL
ptharris
Postby gordon1 » Mon Feb 01, 2010 2:53 am
what power did you get
were are you from
gordon1
Postby ptharris » Tue Feb 02, 2010 9:55 pm
New Zealand, 257kw at the wheels
ptharris
