So I updated the ecu definitions for romraider and I been getting used to the new arrangement of tables and such. I stumbled that now there's an option to adjust fan control on the 32bit ecu that was only available on the 16 bit ecu.
I'm still figuring out how to work this since I want the fans to come on at certain temperatures because at the current setup the coolant temps will shoot up to high for comfort after the 1/4 mile pass so I want to take care off that.
Still I would want to know how to set up this tables properly.
For example I'm having problems identifying when Mode do the M1, M2, M3 etc modes kick in. I'm having difficulties matching up the on and off modes.
Freon if you can chime in on this it would be of a grate help!
