Hi,
I have an ECU that has been previously flashed by Kingpin using ECUTek.
I know that I can read/flash the entire ECU, but can I modify the ECU contents using the tools that are [will] be available ?
Several points to consider:
1) Clark who flashed it left Kingpin, so I cannot get Kingpin to reflash
2) Even if I wanted to start from scratch, I don't think I can do this without a stock ECU image
3) I consider ECUTek's IP to be the flashing process. The tuning process to be the tuner's IP. The ECU and the format/workings of the ECU to be Subaru's IP. I own the ECU, and thus have the right to modify the contents. I am not reverse engineering the flashing process, nor am I trying to sell or distribute the map as-is, it is for my own benefit.
