Newbie questions.
Newbie questions.
Postby wrxsti » Sat Mar 11, 2006 10:12 am
Hi All!
I ran into this forum some time ago. I ordered the cable to log and rip the code out of my ecut**ked EUR 2004 STI.
I have downloaded the file from the ECU, but can't seem to find the corresponding xml files.
I must say I'm new to this and haven't figured out yet how the system works. I assume I need the ecu name.
When I Log using ecuexplorer (which says a 2001-2002sti is connected)the logfiles say AG820-821. Is this the ecu name?
When I open the .hex in ecuedit it say:
Cant find map description for A4RN1XXX.
Add this ecu for describe?
Is this the ecu type?
A little help for gettin'me going would very much be appriciated!
I will attach my hex file.
Thanks in advance for helpin'the newbie's :)
Barry
2004sti2litereur.txt
eur spec 2.0 sti my2004 ecut***d
(ren to .hex)
(192 KiB) Downloaded 855 times
wrxsti
Postby NeverLies » Sat Mar 11, 2006 11:56 am
Your ECU has been downgraded to a 01 02 EU STI, probably during ***TEK remap.
So yes, AG820 is the ecu type for a 01/02 STI (internal name is A4RN1XXX.)
No XML def already exist, you will have to start one on your own ;)
