A8DH200Y 2006 EDM WRX definition
Postby korhan » Sat Jun 09, 2007 3:29 am
we all eu people waiting for the def...
do you have an idea when will it created we bought the cable but cant flash our cars:(
korhan
Re: A8DH200Y 2006 EDM WRX definition
Postby Jon [in CT] » Sat Jun 09, 2007 6:44 am
korhan wrote:we all eu people waiting for the def...
You could use Enginuity to modify/edit your ROM image on the PC and then use EcuFlash to write the modified/editted ROM image to your ECU.
http://www.enginuity.org/Documentation/SupportedECUs
Postby korhan » Tue Jun 12, 2007 7:04 am
thanks for your reply:)
we already take the hex file with the enginuity, and inherit the A8DH200X to the 200Y definition with the flash method of 05 stidbw base. but we didn't try to reflash because we got afraid. do you think we can reflash with this procedure safely.
korhan
Postby korhan » Wed Jun 13, 2007 3:38 am
waiting for the answer or xml:)
korhan
Postby merchgod » Wed Jun 13, 2007 5:05 am
flashmethod for that rom is sti05.
merchgod
Postby ravenhil » Sat Jun 30, 2007 12:02 pm
That has been done with limited success. However, injector scalings, among other features, are not present in Enginuity.
ravenhil
Postby merchgod » Sat Jun 30, 2007 2:39 pm
ravenhil wrote:That has been done with limited success. However, injector scalings, among other features, are not present in Enginuity.
Umm, what? Injector scaling is most certainly supported in Enginuity.
merchgod
Postby ravenhil » Sun Jul 01, 2007 3:20 am
no sir! I was able to download a .hex file from my buddy's EDM 06 WRX in ecuflash but i get really wierd tables with x values that is not in ascending order. I get plenty of invalid tables too. Injector scaling is rated at 75000+ cc/min. :!:
The closest def i can find was USDM 06 WRX so i "inherited" its values (sorry, my cc speak is appalling, I know) and got the above. When I used Enginuity, there are limited values.
Check this out...
look! no injector scaling!
ravenhil
Postby Jon [in CT] » Sun Jul 01, 2007 6:38 am
ravenhil wrote:When I used Enginuity, there are limited values.
You must set your Enginuity User Level to at least 3 in order to modify injector scale values.
View->User Level
Postby merchgod » Sun Jul 01, 2007 8:10 am
What Jon said. Plus you should download the latest ecu defintions (which are newer than those included with the Enginuity download):
http://www.enginuity.org/about360.html
Plus nearly all your questions and problems are answered in the Enginuity FAQ:
http://www.enginuity.org/Documentation/EnginuityFAQ
merchgod
Postby ravenhil » Mon Jul 02, 2007 12:29 am
doh!!! it works! what a relief! thanks, you guys rock!
ravenhil
