Ok guy's,
Here is the latest attempt to use the Ecuflash program to obtain an image of my ecu.
I have a Cobb Stg 2 AP flash. Attached is the error that I received.
I'm using Cobbs cable with a Belden serial to USB converter.
Any help?
[0.000] kernel flash disable
[3.045] denso02_bootloader_cmd_start
[0.020] 1452 byte kernel read.
[0.000] kernel checksum is valid (n = 2).
[0.200] writing denso kernel area addr: 020000 len: 05AC
[2.924] kernel get version
[2.013] unable to load kernel
[42.071] kernel flash disable
[3.084] denso02_bootloader_cmd_start
[2.874] kernel get version
btw, everything is hooked up appropriately, green test connector and I tried w and w/o the flash block.
