S54fan wrote:The ECU seems to pull 2 degress out for a knock sum of 6 and start to reduce the octane number. However, 1 extra degree on the timing map can be enough to change a trivial knock sum of 1 or 2 into a 6 or 7. I find that (as long as the AFR is correct) retarding a degree in the zones that get knock sums of 6 or 7 usually sorts it out and makes it smoother. I tune to a maximum knock sum of 3, that way the ECU will always try to increase the octane number to maximum.
That is odd, 1 KS for me removes 1 degree timing. 2 removes 2, 3 removes 3.. The maximum it removes is 3 degrees then the ECU begins to refer to your low octane timing map.. Interpolated according to your current "octane" as it shows in EVOScan.
If OCTANE = 100 then you're running 100% "Hi-Octane" timing/fuel maps.. :}
But, hey, maybe I'm way off
