power dip at 3.5k rpm??
Postby Hobbes » Thu Aug 03, 2006 10:16 pm
You have isolated it to a mechanical problem by changing the ECU rom but more so seeing it with stock configuration.
This may be the problem
Check the fuel correction factor. (normally thrown off by poor CAI, leak in the intake system or problem O2 .)
Reasoning:
When the ECU is forced to make fuel correction (up to 25%) it throws off its ability to make adjustments when you go through the c/o loop transition. Because the AF correction is so far off the ECU cannot keep up with that transition.
Hobbes
Hobbes
Postby west_minist » Fri Aug 04, 2006 5:01 am
For each log, I am see a o2 problem.
Time will tell.
Postby west_minist » Tue Sep 12, 2006 4:28 pm
Just a little tired tonight and nothing to tune for tonight - which is good :)
I love this WRX and I cannot wait to see one day it is working.
Here is the car in test mode w/ oem wg=0
The owner had this rom, so if something is not log, you can request the owner to logged it, if he can.
Peer through the logs and see what the issue could be :)
noboost #2.rar
(10.56 KiB) Downloaded 477 times
no boost1.hex
(192 KiB) Downloaded 650 times
