tried the reflash
Postby treefrogaz » Sun Apr 09, 2006 6:12 pm
A4TF300F 2004 wrx wagon
philwrxwagonfix.hex
(192 KiB) Downloaded 762 times
treefrogaz
A4TF300F with 02 CEL fix
Postby gethin » Sun Apr 09, 2006 6:25 pm
Test at your own risk etc
offsets changed
0x0002C4B5
0x0002C4AD
0x0002C3F1
AH791-A4TF300F.rar
A4TF300F with rear 02 CEL fix
(80.55 KiB) Downloaded 516 times
gethin
Postby treefrogaz » Sun Apr 09, 2006 6:36 pm
did you change the map i sent you or a different one if a different one what are the offsets you changed
treefrogaz
Postby gethin » Sun Apr 09, 2006 6:55 pm
Here's the file you posted with the above offset fixes.
philwrxwagonfix.rar
(80.54 KiB) Downloaded 473 times
gethin
Postby treefrogaz » Sun Apr 09, 2006 6:57 pm
ok cool thanks
treefrogaz
Postby gethin » Sun Apr 09, 2006 7:03 pm
The file you posted has quite a lot of differences between it and the stock A4TF300F file......do you know what was done to the ECU?
gethin
Postby treefrogaz » Sun Apr 09, 2006 11:11 pm
Yeah i have been tuning on it. Boost, fuel, timing, and some other things
treefrogaz
Postby gethin » Mon Apr 10, 2006 10:27 am
Cool. Let me know how the CEL fixes worked!
gethin
Postby treefrogaz » Mon Apr 10, 2006 4:37 pm
So far both ecu have not triped the cel yet i will keep you posted
treefrogaz
Postby GotWRX03 » Mon Apr 10, 2006 8:21 pm
anyone working on this CEL fix for MY03 - A4TC400L?
I'd greatly appreciate it...
GotWRX03
Postby gethin » Mon Apr 10, 2006 9:05 pm
Here you go
Offsets changed on unmodifed stock A4TC400L ROM
0x0002C9B5 03037 to 05 00 00
0x0002C9AD 03038 to 05 00 00
0x0002C8F1 03139 to 05 00 00
Gethin.
A4TC400L.hex
A4TC400L rear o2 CEL fix
(192 KiB) Downloaded 796 times
gethin
Postby treefrogaz » Tue Apr 11, 2006 2:32 pm
well the cel came on for the A4TF300F 2004 wrx wagon today any ideas for this.
treefrogaz
Postby gethin » Tue Apr 11, 2006 3:09 pm
Strange. I've double checked it again and attached. This is the modified file that you posted.
If it still fails then i'm missing something here....
philwrxwagonfix.rar
(80.54 KiB) Downloaded 498 times
gethin
Postby treefrogaz » Tue Apr 11, 2006 3:21 pm
yeah thats the one i put on his car i dont know. where are you getting the offsets for the cel lights from maybe i could help.
treefrogaz
Postby gethin » Tue Apr 11, 2006 9:38 pm
I was doing a HEX search for 030037 030038 and 030139 after scanning the other threads on openec covering this topic and then inserting 050000 over those locations to disable the CEL. Sometimes I found duplicates elsewhere but the correct offsets are usually bunched together at the end of the file at 0x0001... or 0x0002...
gethin
