2005 STI (USDM) CEL and EcuExplorer
Hello,
I have been catless for a couple of months and I finally received the dreaded CEL. I have been reading on EcuExplorer for the last couple of days, but I'm still unsure on how to clear/disable the CEL. Some post state to replace the code with 050000 and others state to simply raise the values higher so the CEL won't come on. Another post states that you can clear the CEL by using the reset function in the software. I'm confused, which one is the correct method? Will resetting the ECU get rid of the CEL for ever or just until it comes on again? I appreciate any help. Thank you.
