WRX Unable to log knock everything works besides this
02 WRX Using K-Line sample
I pull a csv using the sample renamed to logcfg.txt It generates the CSV files, they automatically open in excel. I see:
sample time RPM load speed IAT coolant_temp battery_volts mrp MAF throttle timing WGDC IPW IAM clutch_sw brake_sw IDC
I do not see any of the knock variables listed. do I need to add them to the sample to pull?
Should I be using a different sample fine? Like CAN etc..
I also heard something about updating the ROM with Romraider could the map being a tune from an older version of Romraider be part of the problem?
Will opening in new version of RomRaider and re-saving resolve this?
Let me know I'm enjoying what it can do! Hoping it will do as promised!
